viper r/s 03 mitsubishi outlander problem
copout221
Copper - Posts: 69
Posted: February 19, 2007 at 11:57 AM / IP Logged
 Need some advice. Customer is complaining that their vehicle is shifting incorrectly and the drive indicator on the dashboard cluster is not illuminating. I checked all the fuses inside and outside without any evidence of a problem and reset the computer. Any other ideas on what could cause this. R/S system installed on Saturday. 2003 Mitsubishi Outlander 4Dr.
Don't fool with it if you don't know what it is !!
Hymer
Silver - Posts: 695
Posted: February 19, 2007 at 12:03 PM / IP Logged
Make sure both accy's are powered up and the IGN is powered IGN blu/black ACCY 1 blue/red ACCY 2 blue/yell. Its a pretty easy install. Could be a timeing isse.. accy's up before ign or vise sersa. Also check the parking lite connection + GREEN / WHITE by fuse box...
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
copout221
Copper - Posts: 69
Posted: February 19, 2007 at 12:07 PM / IP Logged
Thanks... I will go back over everthing you suggested. Hopefully it is just a connection issue. It is also doing this when started with the key.
Tuesday, June 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
