power locks, 2002 ford e250
fauxman2000
Posted: August 15, 2007 at 7:37 PM / IP Logged
I have a 2002 ford E250 that had power locks installed about 2 years ago. When I shut off the van my locks don't unlock and you can't even get it to unlock pushing the remote. It will lock each time I start truck or push lock on remote. Once in a blue moon it works correctly but not often .This just started about 3 weeks ago and it's driving me crazy. Any suggestions? I am somewhat handy and might be able to fix it if I knew what to look for. Thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: August 18, 2007 at 7:05 PM / IP Logged
You installed actuators?   Have a look at the relays. Check the trigger output. Does the actuator make any noise when it does NOT work? Is i straining at all?
Pull the door panal and have a look. Also, look at the wires going into the door at the boot.
steezs
Copper - Posts: 172
Posted: August 19, 2007 at 3:28 PM / IP Logged
If they are actuators maybe the connection is just lose inside open it up and tighten the screws connecting to your lock bar, you'll know what im talking about when you take it apart.
the duce
steezs
Copper - Posts: 172
Posted: August 19, 2007 at 3:30 PM / IP Logged
Inside the door panel
the duce
fauxman2000
Posted: August 19, 2007 at 5:22 PM / IP Logged
I didn't do installation. Is there a main box that controlls the signal to lock and unlock when  you turn ignition on and off.?  It's not individual locks not working, they either all work or all fail. This weekend they were operating most of the time but didn't occasionally. It's frustrating when it's so sporatic. Iv'e traced the wires to individual locks but there  must be a centralized box that sends out the signal thats malfunctioning. Any other ideas? Thanks John
steezs
Copper - Posts: 172
Posted: August 19, 2007 at 5:31 PM / IP Logged
If your saying sometimes they work and in one direction they work open the door panel and look if the connection between the electric lock and the lock bar in your truck is lose before i check any wires. Its probably like lose screws.power locks, 2002 ford e250 - Last Post -- posted image.
the duce
KarTuneMan
Posted: August 19, 2007 at 7:24 PM / IP Logged
I'm thinking this main control box you are looking for is the brain of the keyless, or the relays that control the actuators. Look under the dash Givin what you have said about the actions or lack there of, of ALL the locks at once, there can't be a loose screw on a rod, or individual actuator.
Wire problem, NOT actuator screw loose.
Friday, April 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
