Getting wire into Dodge Ram doors
giff
Member - Posts: 38
Posted: November 29, 2002 at 10:03 PM / IP Logged
Any tricks on getting new speaker wire through the rubber tube that bridges the gap between the door  and the car?
Platinum - Posts: 12,488
Posted: November 30, 2002 at 12:18 AM / IP Logged
You have to take the door panel off and pull the rubber boot off from the door and the body so the rubber boot is dangling on the wires. You will be able to see light from outside when you do this ( from inside the cab ) and you can run new wires through the door and into the boot and then through the cab.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
