2005 chevy full size 2500 h/d problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101271
Printed Date: April 24, 2026 at 9:56 PM
Topic: 2005 chevy full size 2500 h/d problem
Posted By: taylormade1975
Subject: 2005 chevy full size 2500 h/d problem
Date Posted: January 17, 2008 at 10:46 AM
I just installed 2 front door speakers (only), in a 2005 Chevy full size 2500 H/D pickup truck. Hve checked all the fuses and the plugs on both doors, and I have no power to the power door lock, power window, and led blinker in the mirror! Cannot figure out what else it could be... (it's only the 1 passengert side door that is not getting power I guess) Does anybody know about this issue, or has expierieced this problem before?? PLease help as customer is losing faith in us and we really are stumped @ this point. TW
------------- ~Wisdom is knowing what to do next; virtue is doing it.
Posted By: Velocity Motors
Date Posted: January 17, 2008 at 11:38 AM
Check to make sure that the molex plug is clipped in all the way at the switches. Also, did you replace the OEM headunit as well ?
------------- Jeff
Date Posted: January 17, 2008 at 12:08 PM
We have checked the molex connectors on both doors twice and we did not change the factory head unit. Still confused and frustrated, but thank you for the help any how. TW
Date Posted: January 17, 2008 at 1:11 PM
So you cehcked all the fuses at the engine and the ones in the truck with a multi meter ?
------------- Jeff
Date Posted: January 17, 2008 at 1:12 PM
Did you use factory wiring or did you run your own wires into the door boot ?
------------- Jeff
