Dodge Durango warning tone
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10130
Printed Date: March 31, 2026 at 7:13 AM
Topic: Dodge Durango warning tone
Posted By: bulldog277
Subject: Dodge Durango warning tone
Date Posted: February 26, 2003 at 5:47 PM
Does anyone know how to disengage the "key in ignition" tone when the door is open (short of unsoldering it)?
I like to listen to the radio with the door open when I'm working on it or hanging out. On my last car I was just able to unplug the buzzer. This one is soldered into a circuit board with the domelight and door trigger assembly.
If there is not other way then to unsolder it. Does anyone know if this can be done without damaging or interfering with anything else?
Chris
Posted By: securinu
Date Posted: February 27, 2003 at 5:50 PM
snip the light blue wire coming from the key switch and tape it off . it should show ground when key is in ignition.
Date Posted: February 27, 2003 at 8:08 PM
Will this alter anything else like the door triggers? I have a DEI Viper alarm installed and I don't want to interfere with it.
Thanks,
Chris
Posted By: Two_Cold
Date Posted: February 27, 2003 at 8:13 PM
You could always put a small toggle switch under the dash. I've done that in the past for the interior lights.
Date Posted: February 27, 2003 at 10:10 PM
That's a good idea. I might have to do that. What exactly is the light blue wire?
