91 Dodge Caravan AWD electrical Problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10171
Printed Date: March 27, 2026 at 2:07 AM
Topic: 91 Dodge Caravan AWD electrical Problems
Posted By: RocketMan444
Subject: 91 Dodge Caravan AWD electrical Problems
Date Posted: February 27, 2003 at 6:10 PM
Hello. I have a 1991 Dodge Caravan AWD. The other day I had the following problem(s) occur. The first symptom was the power door locks did not work. I then found out that I had no headlights ( switch was illuminated, dash was illuminated and all front and rear parking lights were illuminated), No brake lights and horn. All Fuses are good. Checked voltage at headlight connections and no voltage was evident. The only problems I have previously have had with the van was with the drivers door lock was sticking. Any ideas would be greatly appreciated.
Posted By: Two_Cold
Date Posted: February 27, 2003 at 8:47 PM
Check the +'ve wire off the battery. It should split into 2 or 3 wires (depending on options). 1 or 2 of these should have an inline fuse. Check the fuses.
The relays under the hood could also be faulty. It has been a while since I've built any 91's so I am going by memory here. Check the relays to see if they are working. Unplug them one at a time and use two wires and a meter to test each relay.
I don't think fuses were under the hood yet in 1991, but check around just to make sure. The under hood fuse box is a black rectanular box. If you have one check the fuses.
There also may be a relay or two in the fuse box under the dash, they should be tested too.
The accessories you mention are all devices that work with the key off, so they should all have a common power source at some point, that is why I suspect a relay somewhere. I will ask some of the older repairmen at work what they think and get back to you tomorrow.
Posted By: draasch
Date Posted: February 27, 2003 at 8:50 PM
have you done any work around the fuse box on the left kick panel??? look on the bottom of your fuse box. there should be some relays. check to see if they are pushed in all the way.
i had a problem close to yours and the relays were not in all the way.
good luck,
david
Posted By: Two_Cold
Date Posted: February 27, 2003 at 8:56 PM
Just got off the phone with a repairman who just retired. He said it sounds like a relay. Check the underhood relays and the fusebox relay.
Posted By: draasch
Date Posted: February 27, 2003 at 9:03 PM
there should be relays under the fuse box try there first
Date Posted: February 28, 2003 at 12:04 PM
Hey everyone, Thanks for the information. I'll play with this and get back regarding the results
Date Posted: March 27, 2003 at 5:48 PM
The fault was a power wire from the battery to the connector at the fire wall. Reran a new wire and problem solved. Thanks everyone
