door panels
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10924
Printed Date: March 28, 2026 at 9:12 PM
Topic: door panels
Posted By: draasch
Subject: door panels
Date Posted: March 15, 2003 at 10:52 AM
this may not fit in here but more peeps will read here. i have a 2002 ford E150. i put power windows and door locks in it. the dealer wants $100 for the switches and plastic frames for both doors. i have aftermarket switches that i can use but they wont fit in the frames that came with the van.(they already have some cut outs in them) the panels are grey. do they make grey ABS plastic?? do you have any ideas for me. i just need flat frames so i can cut the holes for the switches. i can send a pic of the frames if that will help.
thks,
david
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: bberman1
Date Posted: March 15, 2003 at 11:09 AM
I use this stuff on custom installs https://www.hi-techindustries.com/cat_page_1.htm it is a called a dye but it’s no different than spray paint. I use it on plastic and its very durable I have  never had a problem with it coming off. Just be sure to match up the color correctly. Now I don’t know were you would buy it but I get it from a detail supply shop https://www.3dproducts.com/cgi-bin/3dproducts/index.html search for dye.
Posted By: draasch
Date Posted: March 15, 2003 at 11:11 AM
thks for your help.
david
Posted By: bberman1
Date Posted: March 15, 2003 at 12:22 PM
hope it works out
