camry 07 wire with cap filled wit gel ecu
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=109655
Printed Date: May 08, 2026 at 10:23 AM
Topic: camry 07 wire with cap filled wit gel ecu
Posted By: aggresivedriver
Subject: camry 07 wire with cap filled wit gel ecu
Date Posted: December 11, 2008 at 1:43 PM
Hey, just a curious question...  Was doing a remote start in a 2007 Toyota Camry, the ECU is to the right under  the hood, so i had to run some wires there.  Anyways one wire is a 10-8 guage (maybe?) wire that is black, but goes into a clear cap filled with gel and at the end you can see the actual wire (maybe 1/2inch of wire) submerged in the gel with a metal connector comming off the end).  The gel is a hardened gel, kinda has a yellowish tint to it...
Just curious as to what this wire is or what it is for?  Didn't touch it or anything, but I had never seen anything like it. Thanks for the info!
Posted By: KarTuneMan
Date Posted: December 13, 2008 at 9:52 PM
Hmmm..... let me think...... NOPE, got no idea!
I sent a link to a mechanic friend of mine, lets see if he reply's
