alarm and remote start on a motorcycle...
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=11036
Printed Date: March 28, 2026 at 2:43 PM
Topic: alarm and remote start on a motorcycle...
Posted By: CBR629
Subject: alarm and remote start on a motorcycle...
Date Posted: March 17, 2003 at 6:59 PM
Anyone ever did this on a bike?
Posted By: auex
Date Posted: March 17, 2003 at 9:47 PM
I've done a couple of harley's. Personally I think it more of something just to have, doesn't really serve any true purpose.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: copcarguy
Date Posted: March 18, 2003 at 7:43 PM
Built my own cheapie alarm years ago when I had a bike. Simply buy a small SPST switch, wire one side to the battery fused at something around 5 amps. hook the other side to a mercury switch and mount it to the frame transversely so that when it is on its sidedstand the circuit is open and when the bike is level and upright it closes the circuit. Wire the other side of the mercury switch to a piezo siren (roughly 85-95db) voiala!
Be sure to ground the other side of the siren.All parts were available at radio shack and it was easy to hide on a bike without much by way of fairings. Low tech but not bad for around $20.00.
------------- R Jackson
Owner/Installer
TRM Emergency Vehicles
Information is advice only and should be confirmed with OEM or quality test equipment.
Boyertown, Pennsylvania
Posted By: Mr_Fusion
Date Posted: March 18, 2003 at 7:47 PM
Did you use a tach wire on the Harleys?
Posted By: auex
Date Posted: March 18, 2003 at 8:32 PM
No, all i used for rs was DEI and switched it over to voltage sensing.
