1998 honda smx dash instruments
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=111515
Printed Date: May 08, 2026 at 9:12 AM
Topic: 1998 honda smx dash instruments
Posted By: georgialude
Subject: 1998 honda smx dash instruments
Date Posted: February 11, 2009 at 8:27 PM
Hi - I have a 1998 Honda smx, which has started a problem when switching on side or headlights.
Instrument dash illumination goes out, fuel and temperature gauges go to maximum, rev counter stops working, and indicator green symbols glow permanently !
The lights still work OK.
Switch the lights off and all goes back to normal.
Problem is i dont have a wiring diagram for this vehicle as its an import.    Suspect an earth fault, or relay problem ??   but dont know where to look !
Anyone experienced similar kind of thing with any other honda model, or guidance on possible relay location welcomed.
many thanks
PRIMEVAL
Posted By: k7smx
Date Posted: March 23, 2009 at 12:59 PM
You'll find it very difficult finding a wiring diagram for SMX.  I recently used the CRV (1997) wiring diagram to to install equipment.  The colour coding is identical and you'll need to figure out which wires to dis-regard (e.g. the SMX has two window closing switches whereas the CRV has four as standard).  The wiring diagram can be down loaded here.
Regards,
K7SMX
