a very cheap faultfinding tester
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=123669
Printed Date: May 13, 2026 at 5:29 AM
Topic: a very cheap faultfinding tester
Posted By: gerry1212
Subject: a very cheap faultfinding tester
Date Posted: September 25, 2010 at 5:49 PM
you will need a plastic box big enough to hold 2 lampholders and lamps 6 / 12 / 24 volt, whatever voltage you are testing.
you will need 2 diodes, and 2 crocodile clips (large) and 1 probe, with 3 lenghs of cable. connect and solder (centre cable (yellow)) to both lamps one (orange lens) and one (red lens), solder 2 diodes anode to kathode faceing away from the the two lamps, solder 2 cables (all long enough) to each end of lamp holders. the orange lamp cable (orange cable). the red lamp (red cable), this cable has a probe. this probe will check any bad earths. the yellow cable go's to the battery positive (battery positive diconnected), the orange cable connects to battery lead (to make circuit orange lamp will light). the red probe can be tested by pushing on the negative terminal (battery). you cannot short out any wiring because the lamp and doide (in circuit). if doides reversed will check (positive connections)
------------- gerald pannier
Posted By: howie ll
Date Posted: October 01, 2010 at 9:56 AM
Great idea except the bulbs will draw enough juice to fry most ECUs.
Both Snap-On and Mac market LED versions. If you are into that get a power probe, it will do what you are suggesting more safely.
