Can 2 amps run 3 12’s?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=12494
Printed Date: May 15, 2026 at 9:50 AM
Topic: Can 2 amps run 3 12’s?
Posted By: HLthe1
Subject: Can 2 amps run 3 12’s?
Date Posted: April 21, 2003 at 7:11 AM
Help, I am trying to see if two amps can run three 12's ? I already have the amps and dont want to have to buy another one. It has a bridged output on the amps but I dont know how to hook it up. The amps are an old memphis competition series, they are 2 ar-hc100. They are rated at 1096 watts at 1 ohm.
Posted By: Velocity Motors
Date Posted: April 21, 2003 at 8:36 AM
Are the 12's SVC or DVC ? You should not run 2 separete amps to 3 subs because the amps () can not perform in unison and one of the amps will have more power than the other causing the subs to perform out of synch. If the amp is 1 ohm stable you can probably run all three subs off the one amp, depending on the voice coils and how many each have. Let us know.
Posted By: HLthe1
Date Posted: April 22, 2003 at 8:52 AM
Both the amps have a bridged output rca type connection and I was wondering how if this is what is used to join them together and if it could be done. The amps are 1/2 ohm stable. If I use three on 1 amp should they be svc or dvc? Also Jeff is there a diagram to change the amount of ohms seen by the amp for the three subs together. LIke make the amp see 4 ohms when just riding and 1 ohm if i decide to compete? If so please help, not that knowledgable with relays.
Hiram
Posted By: wvsquirrel
Date Posted: April 24, 2003 at 2:37 AM
What type of amp's are they?
Here's some diagrams... (I couldn't get the last one, but you can also wire 3 4ohm DVC's in parallel to get a 0.67ohm total load)
2ohm DVC's
posted_image
posted_image
4ohm DVC's
posted_image
4ohm SVC's
posted_image
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
