stand alone proximity detection/alert
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126695
Printed Date: April 27, 2026 at 2:32 PM
Topic: stand alone proximity detection/alert
Posted By: two12
Subject: stand alone proximity detection/alert
Date Posted: March 23, 2011 at 10:53 PM
I have a small RV and I would like to use a spare DEI508 proximity sensor as a stand alone (no alarm system brain) motion sensor that will beep when someone gets too close while Im asleep.
how would I use the trigger to make a beep of some sort and what would be a good source for the beep sound?
also for anyone that is intimately familiar with this sensor, what is the "factory adjust only" for exactly?
thanks
Posted By: KPierson
Date Posted: March 24, 2011 at 4:48 PM
If I'm not mistaken that device outputs a short pulse when it is "violated". You could connect that output to a Off Delay Timer Relay and set that timer to 3-10 seconds. You could then pick any kind of buzzer/siren/light and use that as a trigger.
------------- Kevin Pierson
