advice, mimic abs signal
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=126866
Printed Date: April 27, 2026 at 9:06 PM
Topic: advice, mimic abs signal
Posted By: frank mc
Subject: advice, mimic abs signal
Date Posted: April 06, 2011 at 4:09 PM
hi guys, i would like to know how to mimic the signal from my abs unit,
before we removed the unit we got some readings from the signal wire in question, what we got was .8 volts for 9 seconds & then switches to 12 volts, this happens every time the key is turned on.
any advice on how to do it would be really appreciated
regards frank
Posted By: howie ll
Date Posted: April 06, 2011 at 6:07 PM
You're asking for lots of problems. Don't go there.
Posted By: oldspark
Date Posted: April 06, 2011 at 8:34 PM
x2.
Unless you are simulating or figuring slip etc. (But thats' from the sensors.)
But to deactivate or modify - NO!
Not that I'll cro over it - I am all for deactivation, but that must be OEM etc. (In fact I will not but a vehicle whose ABS and Stability Controls (etc) can not be disabled as required...)
