damage a relay by crossing meter leads?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=128440
Printed Date: April 19, 2026 at 5:22 AM
Topic: damage a relay by crossing meter leads?
Posted By: vayankee
Subject: damage a relay by crossing meter leads?
Date Posted: September 04, 2011 at 10:43 AM
I had no sound from my fuel pump in trying to start my '85 VW Quantum. I tried to check for power at the connection at the fuel pump-nothing. But what I later realized that I had reversed the meter leads - hot lead to the ground conneciton, and the common lead to the hot wire. Before this realization, I had replaced the original relay with two back-up relays, and neither of them worked though I was ofcourse testing with the meter wires not hooked up correctly.
I am pretty sure the back-up relays were good. I had had fuel pump relay trouble several years ago, and picked up these backups. I am pretty sure that I tested them in place before storing them in my glove box. Too bad I didn't try them before my testing!
The relays are Kaehler 3.300.210, with the following spade connections: 87, 30, 15 Ignition coil), 31 (ground), and 31b.
To test, I inserted a relay from another usage (with 87, 30, 85, and 86 connections) in the fuel pump relay position, and the fuel pump was activated with the key in the on position.
The meter still works, but did I blow those backup relays by crossing the wires?
Thanks!
Posted By: oldspark
Date Posted: September 04, 2011 at 5:04 PM
Not if merely +ve & -ve VOLTmeter leads were interchanged.
If you were measuring CURRENT from +ve to -ve, then yes - check fuses - an ammeter is like a short circuit.
Same of you TOUCHED the (multi-)meter probes together hence shorting the relay...
I was going to say that your fuel pump (relay) should only be getting power power (relay actuated) when cranking or the engine is running. Having the fuel pump on only because IGN is on is not done by car manufacturers, nor by anyone with an aversion to live cremations.
That is dangerous!
I strongly suggest you correct that wiring NOW unless you are using the 3.300.21 with standard wiring.
It is easy enough to use a common relay. Those Europeans love to complicate things with specialised "pulse" and constant relays like the KAE 3.300.21 etc.
Depending on your IGN & STart switching, you can use an SPDT relay with 87a to the STarter cranking signal (key), 87 to IGN +12V or fuse battery +12V, 30 to the pump +12V, 86 to the alternator's charge light terminal, and 85 to GND.
But I prefer the SPST relay version where 30 & 87 are between your fused battery and the fuel pump (like above). 85 is GND, and 86 is your "trigger source".
Your trigger source is the same alternator charge light source through a diode (IN4004 etc) to 86 (ie, +12V when charging).
The same for any other +12V switching source you wish to add: eg, from IgnKey's STart position via a diode to 86 for the "priming" function (if the carby is dry), or a "bypass" +12V switch (via diode) to 86 for a manual on (for testing the relay or pump; draining the tank; etc).
The main thing is using the diodes to prevent back feeds.
[ The SPST version is simply the UIBI (Ultimate Intelligence Battery Isolator) but applied to connect a fuel pump instead of a parallel battery. ]
Posted By: vayankee
Date Posted: September 04, 2011 at 6:23 PM
Thanks for your reply! Yes, I was measuring power/current at the disconnected wiring connection at the fuel pump. I did not hear a short occur, but I know the relays were bad after my shenanigans. A friend showed me how to test them on a bench. We tested the good relay I mentioned above and we could hear the switch/contacts clicking, but there was no sound from the original or backup relays.
Yes, the VW is designed to build up fuel pressure when the key is turned to the on position, as you mentioned. That's the sound of the fuel pump working that I was looking for. And I guess that's what the Kaehler relay is designed to accomodate. I don't know why VW wanted fuel pressure to be built up like that - I'm not an engineer, obviously. But thanks for your suggestions on alternative relays.
My ignorance about 12 volt DC systems got me in trouble here, and I appreciate your help with this. Just a couple of weeks ago I tried to find a class locally on auto electrics, but the only one I found is offered just to high school kids. There was one for us "adults," but budget cuts killed it.
Also, I was afraid that something else might have caused those relays to malfunction, like the used alternator that I had installed a week or so (I initially miswired the blue lead from the alternator warning light to the body of the alternator instead of to the D+ terminal).
Thanks again!
Posted By: oldspark
Date Posted: September 04, 2011 at 7:39 PM
Phew! Grounding the charge lamp to won't do damage - it will merely turn on the charge lamp when the IGN is on. That's what the D+ aka L terminal does - grounds the lamp when not charging, and swings to +12V when it is charging (hence powering fuel pump and UIBI/isolator relays etc, and extinguishing the chargeLamp because its other side goes to IGN (meter/gauge) +12V).
Grounding the D+ output shouldn't do damage if it isn't charging, and it might not charge because usually the D+ and charge-lamp must be connected to provide the initial excitation current to the alternator. If it is charging, the D+ will swing to +12V and that can cause damage (if shorted to GND).
It is NOT EFI is it?
Not that it matters much - for both systems (fuel injection or carburetor), the fuel pump should turn on for a while before starting. I assumed carby for various reasons....
For carbies it is merely to ensure that the fuel bowl is full before cranking. (If empty, the car won't start, hence no alternator charging, hence the fuel doesn't pump, so the car never starts.)
EFI is similar, though that's more ensure the injectors do not operate whilst dry and have the proper fuel pressure (which is required for correct fuel injection quantity), and disable any low-pressure warnings or shut-down if they are fitted.
But EFI fuel pumps are normally controlled by the EMS/ECU so there is absolutely no reason to uses anything other than a plain SPST relay.
Carbied cars on the other hand did not have ECUs etc. Until the 1990s even the addition of DIODES was considered to complex (or unreliable) for some - hence the use of the SPDT fuel pump relay circuit - ie (with thanks to Tezza):
posted_image
(as posted in the12volt's wire to fuel pump wire, fuse gets very hot)
Posted By: vayankee
Date Posted: September 04, 2011 at 8:46 PM
Yes, the car has FI, Bosch Jetronic. And that relay diagram that you included above (Thanks,BTW) is what I put in to the Fuel Pump relay slot, and it worked, as I wrote above.
Let me check with some other Quantum owners and get back to you on why VW used the 87-30-15-31 relay insted of the SPST relay. I do know that some owners suggested using a SPST relay for "limp home" which it obviously would achieve.
Thanks again!
Posted By: oldspark
Date Posted: September 04, 2011 at 10:11 PM
Rats! I have info on the K & L series, but not F.
My book reckons the 82-85 Quantum is K-Lamda and 86-88 Quantum is KE (CIS-E).
Both are based on ignition (spark) signals to activate the fuel-pump relay....
... and there's the relay - same schematic as for that relay you quoted....
The fuel-pump is grounded. Its +12V wire is RY (red yellow).
RY goes to the relay and is effectively 87 (relay output) with its 30 RED to "battery" via an internal fuse. (Why not mount them externally?)
The relay GND is BRN (brown).
But it has 2 inputs - Red-Blk to IgnCoil-, and Blk to Ign Switch Term 15 which IGN +12V (in DIN72552: "Switch-controlled plus downstream from battery (from ignition switch)" or "output of ignition/driving switch" etc).
The internal relay's coil looks to be hot (to IGN +12V) and is grounded via the internal circuit - ie, if the IgCoil is pulsing (engine running are cranking), the coil is grounded to the relay energises.
Ok - cool, that's one way to combine "both cranking and run" energisation of the fuel pump. (Clever, though I prefer the alternator etc, with an air-flap signal as a fall back, then coil pulses as a 3rd option. But that's a simplicity and reliability consideration & IMO.)
Anyhow, a standard SPST will substitute as an EMERGENCY relay by ignoring the IgCoil- connection as you described earlier.
However this is DANGEROUS and generally illegal. It means the fuel pump is on whenever the IGN is on.
Competitive sports and most Laws/Regulations prohibit fuel-pumping if the engine is not running. Hence the use of alternator charging, air-flap, or spark signals.
Otherwise if you have an accident and sever the fuel line, the engine may stall but the fuel pump keeps pumping.
Maybe that's not a problem for VW owners, perhaps they got used to being burned alive from the old Beetles' front fuel tanks (and exposed electrics and under-seat batteries).
And as much as I like that final scene from Mad Max (stateside's "Road Warrior"?), we have a bushfire issue down here....
Anyhow, I think the simplest is an plain relay as per earlier - ie, SPST with alternator D+ via diode to 86 and cranking +12V via diode to 86; else a SPDT with D+ to 86, cranking +12V to 87a and IGN +12V or battery +12V to 87.
BTW - the limp-home mode for a failed alternator is to disconnect the D+. The dash lamp(s) should be enough to pull up and energise the fuel pump relay.
Note too that that "fuel pump" relay might also control other things like fuel cut relays, or as for the Quantum, the Red-White +12V to Control Pressure Regulator & Aux Air Reg.
But seriously, why didn't the ECU supply a signal for fuel pumps etc instead of having some separate mechanical relay with electronics to monitor pulses etc?
[ I never understood that logic, however it is far better than those that use oil-pressure as the only trigger (bad!) else a bypass for ECU control (as per the Holden Camira and others I have seen). ]
Posted By: vayankee
Date Posted: September 05, 2011 at 8:54 AM
Thanks for looking up the diagram for my car. Actually, I believe that the '82-'84 models used CIS FI, but mine has CIS-E. So the L Jetronic is the system on my car. Your description of the wiring matches the diagram in my Bentley manual.
Your take on the Emergency relay sounds right to me. Other owners have carried, not necessarily used, a jumper wire to fire up the fuel pump to get home. I believe that the standard relays may have had some weak/poor soldering on the little pc board in the relay-some talked about touching up a spot or two to get the relay working again. I just ordered a standard one and a backup to put my car back in service. FYI, the lowest price is roughly 23.00 here.
Thanks for the point you made about limp home with a failed alternator. I'll have to keep a 8mm socket in the car to get the nut off the D+ terminal  :).
.posted_image
Also, you mentioned an internal fuse in line to the fuel pump. I'm not really sure what you mean there (Perhaps you are seeing the circuits at the top of the page which in my manual are in gray. That gray signifies just that the wiring shown is located in the relay/fuse panel shown above). There is a 15 amp fuse for the fuel pump in a fuse box just underneath the relay panel as you can see above (5th from the left). I of course checked the fuse, and even pulled out the relay panel to see if I could see any scorching on the back side, when I could not see power from the relay slots. The fuel pump relay is the one in the pic above that is 2 in and 2 above from the left.
Yes, I had heard about fuel cut off, but I will check on how that is accomplished in this system.
Also, you wrote: "But seriously, why didn't the ECU supply a signal for fuel pumps etc instead of having some separate mechanical relay with electronics to monitor pulses etc?" Good question. The ECU in use here is as I understand it two devices-one for ignition and the other, larger one for oxygen control. In effect they used  as simple a system as they could, perhaps to meet fuel economy/emissions standards worldwide. Actually, the system on my car has been adpted to run with a slightly more advanced hall effect distributor setup to accomodate a higher compression engine. The original engine was replaced after 205K miles with a Audi 90 block and Jetta head, bored out cylinders and larger than original throttle body, plus a knock sensor. So you might see why I "fiddle" with this car!
Boy, I have really enjoyed this discussion, and very much appreciate the knowledge you have shared with me! I hope that you are having as much fun with your vehicle!
Posted By: oldspark
Date Posted: September 05, 2011 at 10:05 PM
I have a similar system in my 1986 Holden Piazza. Unfortunately they went backwards from the "all electronic" I-TEC EFI & Ignition to an mechanical RPM & vacuum advance distributor (reluctor type) with ECU retard capability based on the knock sensor.
Though it's JECs or similar, it is one of those Jetronic licensed copies. If only they used the original I-TEC system! (No distributor wear etc.)
I know the Hall Horrors (Siemens HKZ-101 sensors etc). Not that they are horrors - they were my preferred system until I figured out how much simpler and more rugged (and not that it matters, but more accurate) the reluctor systems are - provided they are the newer "singe pole" types available since the 1970s yet not applied to most cars until the 1990s (eg, both my 1986 Piazza as well as similar vintage Delco'd Nissans & GM/Holdens use the crappy old horizontal reluctor coil with multi-pole rotor and pickup).
Re the fuse, the other pic I had is the same as the schematic on:
posted_image
(the above pic being extracted from kae_relais_01.pdf).
But my reference clearly shows that upper RH "gap" in the 87 circuit to be a fuse. (If you can replace that fuses, then fine. If not, why replace a relay because of a blown fuse? I'd rather omit the fuse and blow the relay! But I can see a safety argument - after all, it's not as if anyone could bypass that fuse by jumpering 30 to 87... [yes, I am mocking that design... I mean, I am merely preempting the common shallow replies I often get.])
Incidentally, the above reference is a Mitchell "Electronic Fuel Injection; Imported Cars, Light Trucks & Vans", Edition 1 (1989). (That was one of my "I don't need but what a great price!" purchases at a market that years later I found to be almost priceless. Yay! FTW.)
You may not have other fuel cuts. IMO that is not required for EFI because as soon as the pumps stops, the fuel pressure & flow stops. (Or very quickly thereafter, ignoring surge tanks.) Though maybe as a way of sealing the fuel tank in case of a line rupture...
But that "engine is running" signal - whether from an alternator L/D+ circuit or spark sensor etc - it often used for fuel pumps, electric chokes for carbies, and early ejection seats (till they figured out engine running could still be in the shed; later seats were speedo linked so you had a better chance of NOT still being in the home garage, hence it was statistical whether you were killed being ejected into a tunnel, bridge or car-park roof, or being run over by the following truck or evil spies).
Anyhow, maybe I do elaborate somewhat excessively, but however it is done (alternator, airflap, spark), it is a perfect signal for many systems (fuel pumps, battery isolators, etc).
IMO that KEA 3.300.210 is easily FUNCTIONALLY replaced - eg SPST relay with external fuse, and either and external spark sensing circuit, else a diode-OR'd (joining) of D+ & crank signals.
BTW - D+ is often a mere spade connector. Do not confuse D+ (or L = charge Light) with the heavy B or B+ alternator output (to battery +12V and the vehicle). Re- or dis-connecting B/B+ is a totally different consideration!
It's been a while since I discussed EFI.
But yes, I enjoy my 1960s vintage pushrod-engined CARBY vehicle. (LOL!) (Though I am considering converting my next engine(s) to EFI...)
Posted By: howie ll
Date Posted: September 06, 2011 at 5:45 AM
We called your Holden an Isuzu Pizza Peter posted_image
Surely we're talking about the primer circuit here and do NOT swap a standard SPST or SPDT relay for a 31b, the 31b denotes a second ground (earth) switch.
Do you think UK or US English will ever unify earth and ground as used in auto electrics?
Posted By: vayankee
Date Posted: September 06, 2011 at 8:52 AM
In one way we in the US are fortunate that we still get truly imported cars, but for car enthusiasts, not ever seeing a Holden or other such on the roads is very sad.
And yes, I will stay with the VW-designated relay. But the discussion of alternatives has been stimulating, as long as I can follow it!
Finally, you wrote: "Do you think UK or US English will ever unify earth and ground as used in auto electrics?" Not bloody likely on this side of the Atlantic pond, while the media here is heavy with flat-earth type thinking, or arguments without any grounds (Pardon my politics).
Posted By: oldspark
Date Posted: September 06, 2011 at 10:03 AM
(Howie) Ah - here we called the Isuzu Piazza the Holden Pizza, though some just called it a Lemon! (Yes, it's in a "Lemon" book!) That was after GMH (GM-Holden) modified the Piazza's handling - maybe they were contracted by GM to also sabotage Isuzu! Holden not only bought the superseded Piazza body, but the forgot to cancel their second order which lead to one of the biggest "giveaways" of all time - one Piazza to EVERY GHM dealer throughout Australia, and lots donated to quiz shows. Maybe it was called the Impulse in USA because of Isuzu's impulse...
And yes, 31b is defined as "Return line to negative battery terminal or ground, via switch or relay (switched negative)", but in my Mitchell book it is shown as going to "To IGN coil-", hence I assume the "module" in the KAE 3.300.210 is a pulse to gnd circuit. But that cannot be used for the SPST bypass, though a simple jumper from 30 to 87 is all that is needed there noting that it must be manually disconnected when the IGN is off. If an SPST relay is used, the #15 (to relay coil 86) is IGN switched +12V so the relay (hence fuel pump) is off when IGN is off. (Only the "off when stalled" is missing.)
Earth and Ground. LOL! I used to dislike ground, but I now almost prefer it because it is easy to write as GND. However both IMO are incorrect because neither are "safety" earth or ground as used in AC systems. I do prefer 0V which is technically correct, but that can be confusing to some, hence my 2nd preference of Chassis (meaning body/chassis etc).
Flat Earth thinking... LOL - that's another misconception I often (try to) correct. That stemmed from political propaganda some centuries ago where a minority of religions (about 20 out of ~125 as I recall) reckoned the Earth was flat. That was despite 2,000 years ago calculations that put the Earth's circumference to within ~2% of the correct figure.
But yes, media will sensationalise bullsh false & minority thinking as if it were the norm.
How else could they sell unhealthy and useless products, or sell certain political doctrines.
But I shall leave that topic there. I'd hate to ripple the pond. (Not!)
But vayankee has IMO shown his astuteness - with VW electrics as well (LOL). Stick with the designated relay. But if that becomes difficult, you know that there is/are relatively simple substitutes that meet Regulations etc (ie, the fuel pump shallst NOT pump after the engine has stalled).
I agree, stimulating discussion. And no-one has commented on the use of oil-pressure to control fuel pumps. Obviously the Aussie dimwits I had the pleasure of encountering have now understood their stupidity, else aren't on the12volt. Probably the latter I suspect!
Posted By: howie ll
Date Posted: September 06, 2011 at 10:38 AM
I seem to remember that our Pizza couldn't get round corners either, the interior was nasty and the Celicas murdered it.
Citroens here are known as Lemons (Citron), but then French cars are CRaP (Citroen Renault and Peugeot).
Vayankee, the reason you don't see a lot of these vehicles are that they are rubbish!
Could you imagine Americans putting up with the electrical/build quality problems of French/Italian cars? Even in the UK they don't dare sell Lancias.
Why do you think you only see (in no real order of preference), Focus, Golf/Jetta, Fiesta, BMW.
Don't worry about not seeing Holdens, mostly they are UK Vauxhalls with US V8 engines. The hot one was sold here as a Vauxhall and in the US as a Pontiac GTO.
Also we have lots of Chimeras, e.g. Skodas, beautifully built VWs with unfortunately awful quality cheapo SEAT interiors.
Ref Chimeras, Voyagers,Jeeps, made in Austria, a front wheel drive 5 series, the Rover 75, the Honda CRV and LandRover Freelander, Ranger Rover and X5 were two parallel designs that parted company when first Honda then BMW parted company with Rover, even now working on different Land/Range Rovers it's amazing how many BMW and Volvo (the Ford ownership) parts you come across.
Roughly:-
Fiat 500 = Ford Ka
Ford Focus = Mazda 3 = Volvo 50 series = Land Rover Freelander
Ford Mondeo = Mazda 6 = Ford Edge
Vauxhall/Opel Insignia = Buick Regal
etc. etc. etc.
Ref: Gound/Earth, chassis has French connotations, also who remembers chassis apart from truck and Land Rover Defender owners.
How about battery 0v?
Posted By: vayankee
Date Posted: September 06, 2011 at 11:19 AM
Well, I guess I am one of those who notice a pretty face/body first and tend to stick with that opinion until proven otherwise. But now, after your expose of certain makes, I will refrain from trying to import a Holden. Maybe I have been influenced by the great Down Under racers, Denny Hulme, etc. who impressed the he** out of me many years ago.
I did enjoy test driving a Peugeot 503 gas model, though I admit it was because of the ride and the seats and the style. Then of course they disappeared from here. Though there is one a couple miles away, with a turbo on it no less.
And yes, I only see "chassis" in occasional car mag. columns by old timers. But "chassis" does have a nice continental ring about it. (Pardon my French heritage).
Posted By: oldspark
Date Posted: September 06, 2011 at 1:55 PM
Alas Holden tend to export engines. Their V6 is based on some Buick though...
My vehicle has a chassis! (And doesn't a monocoque body arguably have a chassis? - not that I'm up with or into automotive parlance - I just drive, repair and upgrade the beasts...)
And what instead of 0V? A 12V battery has -12V? No! (It has +12V and 0V - unless you'd prefer +6V & -6V with a -6V ground?) But I do remember my "objection" when +ve & -ve supplies became +ve & 0V supplies on circuit diagrams etc. But I eventually saw the light...
Posted By: howie ll
Date Posted: September 06, 2011 at 2:05 PM
Modern Peugeots:-
508 comes to me a few months ago, 4 year old diesel.
No sound from the audio, all OEM(Clarion)equipment. I had a spare amp and tried that, no difference, it turns out there's an "integrator" (preamp?) behind the glove box cost £1200 ($1800). Forget it.
Also particle filter blocked, £1,500 plus locks not working on one door.
They throw them away after 3-5 years here, just too expensive to repair.
Don't get me wrong the 503/4/5 were fabulous vehicles, after that they tried too hard to copy the Germans, loaded with flash, unnecessary electronics, unfortunately only BMWs seem to work properly. Stopped by a customer's car 2 year old Citroen, "why are you opening the door to speak to me?" "Drivers window failed again". They're a bloody joke.
Posted By: howie ll
Date Posted: September 06, 2011 at 3:12 PM
0v return? Not physically correct unless quantum theory has changed but effectively so.
Posted By: vayankee
Date Posted: September 06, 2011 at 4:00 PM
howie ll wrote:
Modern Peugeots:-
That's a shame. All the more reason, to me, to find something good and hold onto it, with occassional diversions like fuel pump relays :)
Speaking of relays, I have another relay question. Having to do with a/c fans. Should I start a new thread?
Posted By: howie ll
Date Posted: September 06, 2011 at 4:02 PM
Yes.
Posted By: oldspark
Date Posted: September 06, 2011 at 8:15 PM
Pardon? Compared to +12V, 0V is correct. (Quantum offsets cancel.)
So Sir Howie, if the +ve terminal of a nominal 12V battery is called or assigned +12V, what (voltage) should its -ve terminal be assigned/called?
Pre-emptive: I hope I "win" this... No - I hope I "don't lose" and learn something in the process. (But if I learn I don't care if I lose because I will have won... Dear Admin - please delete this paragraph - I'd rather lose than post this embarrassment!.)
{Need I add a LOL or emoticon??}
PS - sorry - I deleted by mistake. I was going to add the Devilish emoticon after my "Sir Howie" line....
Posted By: howie ll
Date Posted: September 07, 2011 at 12:34 AM
You've bloody lost me! The quick answer is -12v but then we don't have 24 volt batteries!!!!
Battery NEG anyone?
Posted By: oldspark
Date Posted: September 07, 2011 at 1:07 AM
EXACTLY! Therefore it is 0V. +12V & -12V means a 24V supply.
Battery neg, but neg what? neg-0, neg 12?
Look at amplifier rails, they are a + & - voltage rail/bus with a nominal earth/ground/common at zero Volts...
But I blame those Audio dudes. Until then, I was quite happy with +12 & -12 meaning the 12V battery terminals.
(Actually the change came with the flooding of Op-Amps onto the market about 2 score years ago.)
Besides, be fair - I need to be reasonably correct once in a while....
Posted By: howie ll
Date Posted: September 07, 2011 at 1:45 AM
I'm lost here, isn't 0v what I suggested earlier?
Posted By: oldspark
Date Posted: September 07, 2011 at 4:45 AM
I thought you wrote "0v return? Not physically correct unless quantum theory has changed but effectively so." and later "The quick answer is -12v...." (but you continued "... but then we don't have 24 volt batteries!" which IMO is what I said, namely that to use +12V & -12V means a 24V power supply.
So we are agreed, the correct labeling is +12V and 0V.
Call 0V what you want - chassis (even if floating), ground or earth (despite having rubber tyres in between), or return.
