sub box fill?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13163
Printed Date: May 14, 2026 at 3:20 AM
Topic: sub box fill?
Posted By: eclipse221
Subject: sub box fill?
Date Posted: May 05, 2003 at 8:28 AM
I want to put some fill in my sub box to make it sound bigger.  What would be the best stuff to use for box fill?  I have a bag of polyester batting, would this be any good?
Posted By: bberman1
Date Posted: May 05, 2003 at 9:24 AM
Polyester batting will do the trick
Posted By: alienated
Date Posted: May 07, 2003 at 1:46 AM
i'm getting a 10inch alipine type r and a qlogic box, think i should fill it?
Posted By: bberman1
Date Posted: May 07, 2003 at 10:09 AM
Personally I don’t like the sound you get from a stuffed box. The only time I stuff a box is if the enclosure is too small and I need more volume. But it won’t hurt to try it; you can stuff it and see if you like the sound and if not you can always take it out.
Date Posted: May 07, 2003 at 12:59 PM
what about lining the inside with that dynamat stuff, is that even worth it?
Posted By: bberman1
Date Posted: May 07, 2003 at 7:06 PM
I have never tried it to know first hand
Posted By: Velocity Motors
Date Posted: May 07, 2003 at 8:35 PM
Lining the box won't help your volume but it will help with resonating frequencies.
Date Posted: May 08, 2003 at 10:30 AM
i asked around and i've only gotten "no" as a response. saying that making the sub thing there is more room is a bad thing when your box is the size of your "normal" ft^3.
anyways, if i try it, ill let you guys know.
Posted By: bberman1
Date Posted: May 08, 2003 at 5:06 PM
sounds good
