speaker walls
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13515
Printed Date: May 01, 2026 at 2:18 PM
Topic: speaker walls
Posted By: sm00th4you_75
Subject: speaker walls
Date Posted: May 14, 2003 at 7:34 AM
How does an installer properly design and fabricate a wall for a 89 Honda Civic Hatchback for 4 12" subs?
------------- Bigg Dogg
Posted By: auex
Date Posted: May 14, 2003 at 2:53 PM
Just curious, why a wall for 4 twelves in a hatchback?
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: May 14, 2003 at 4:00 PM
I have never seen a wall for just W7 twelves in a small car such as a Honda Civic and am interested in doing it myself!
Posted By: auex
Date Posted: May 14, 2003 at 6:27 PM
Basically the easiest way would to build either one large box( if you can get it into the car) or two boxes, secure them in place and the build cover panels.
Date Posted: May 14, 2003 at 8:10 PM
Should I build each one seperately, stack them, then cut out the holes on the wall, then build a wooden stabilizer to accomodate the hump in the center, then put the boxes in and then the wall? Now should i downgrade to 10 's instead of 12's? Because I really want a wall in this car and mount my 2 JBL amps in the back next to the hatch with my wire connects, fuse blocks, distribution blocks, and my electronic crossover! I'll be pushing roughly 1400w total power in series but I haven't purchased any subs yet and I would really like to go with some W6's or W3's. What should i do?
