damaged ecm 08 yaris
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135157
Printed Date: April 22, 2026 at 4:07 AM
Topic: damaged ecm 08 yaris
Posted By: Calster
Subject: damaged ecm 08 yaris
Date Posted: October 27, 2013 at 10:25 AM
I may have damaged ecm on 2008 Yaris during R.S. install. There is now no power to the ignition power wire. Car starts with key but no accessories are working. Damage could have been caused by using the wrong wire for Rx(Data in) or Tx(Data out)on the diagnostics connector. I used pin 4 and 5.
Posted By: smokeman1
Date Posted: October 28, 2013 at 9:50 AM
What by pass are you using? What Remote starter are you using?
------------- When all else fails, Read the Instructions
Posted By: Calster
Date Posted: October 28, 2013 at 10:03 AM
PKall bypass, an older Autostart rs model 3471 which didn,t support d2d with that pkall. I initially wired the 2 data wires wrong to the diagnostic plug. I found out after there is a 7 pin plug near the ignition where they should have went. I've checked every fuse in that car and they are all good. Right now the car starts but there is no cabin fan,stereo,PW,RW defrost,wipers ac and the shift lock doesn't release. /:?
Posted By: Calster
Date Posted: October 28, 2013 at 5:16 PM
Figured it out. Popped a fuse-link in the power wire between ignition and ecm.
