toyota axio rear cam
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135313
Printed Date: March 30, 2026 at 8:24 AM
Topic: toyota axio rear cam
Posted By: t&t tech
Subject: toyota axio rear cam
Date Posted: November 18, 2013 at 5:19 AM
I have a 2008 toyota corolla axio, right hand drive, japanese vehicle, it came with stock rear cam and head unit, i replaced it with a pioneer avh-1500dvd deck.
I have had no luck getting the camera to work, i am locating the video signal wires from the camera, however the only way i am getting a video signal is when the stock H/U is plugged in, i have tested at the camera whilst it is on, and i am not getting a 12volt feed at the camera, even though it is on and working. I am getting a single 6 volt feed at the camera, i don't want to put a 12volt feed
directly on the cam, kinda skeptical i'll mess it up.
Anybody on here ever did this? I need some help with this. Any will be appreciated. Thanks.
Posted By: i am an idiot
Date Posted: November 18, 2013 at 1:51 PM
Toyota uses Fujitsu Ten as their OEM radio manufacturer. They do use a 6 volt camera system. You will need to provide it with 6 volts.
Posted By: t&t tech
Date Posted: November 18, 2013 at 6:56 PM
I figured it was something along a six volt camera. Can u help me with what would be the most practical way to supply the camera with six volts.
Posted By: t&t tech
Date Posted: November 18, 2013 at 8:03 PM
Thank you IAAI, for your help thus far.
Date Posted: November 18, 2013 at 9:27 PM
Use a cigarette lighter to USB device. They did one at our other location the other day and that is what they used.
You may want to solder wires to the input end. There will be 5 volts across the red and black wires of a USB cable.
Posted By: t&t tech
Date Posted: November 19, 2013 at 10:55 AM
Posted By: t&t tech
Date Posted: November 19, 2013 at 11:45 AM
Will reply wen i succeed. :)
Posted By: t&t tech
Date Posted: November 25, 2013 at 1:21 PM
Thanks IAAI. It worked. I appreciate ur help.
