2010 toyota rav4 g code remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=135469
Printed Date: April 22, 2026 at 5:20 PM
Topic: 2010 toyota rav4 g code remote start
Posted By: upscaleddesigns
Subject: 2010 toyota rav4 g code remote start
Date Posted: December 05, 2013 at 2:02 PM
I have been researching for a few days now and am not getting too far. I have a 2010 Toyota Rav4 with the "G" key but no smart key. I want to splice in as little amount of wire as possible so was going to go with the xpresskit. I have read over the instructions and all but it is not clear exactly what I need to get to hook it all up.
I want remote start that is it. If it is the same price for an alarm then that works as well. I would rather just use the factory key but a second key fob for further distance is fine. The questions I have are what modules and parts do I need to get and do I hook it up in D2D eliminating some wiring and if so is there something else that I need to purchase as well. I have done remote starts in the past but wanted to try out the xpresskit setup with one of their starters unless there is a different starter that will work with theirs great and save me money. Thanks for the help in advance!
Date Posted: December 06, 2013 at 1:25 PM
Can anyone help me out? I want to order this stuff ASAP for a Christmas gift.
Date Posted: December 06, 2013 at 4:10 PM
Ok it looks like I need the following. Let me know if any of it is un needed or if there is something that I am missing.
DB-ALL
Avital 5303 remote start/keyless entry 2-way
XKLoader2 interface
Do I also need some sort of bypass or anything? Thanks and hopefully someone knows so I can order this stuff up tonight.
Date Posted: December 31, 2013 at 1:51 PM
I am about to install this and want input. ANYONE???
Posted By: kreg357
Date Posted: December 31, 2013 at 3:03 PM
This install guide from iDatalink for their bypass module should help. It gives the necessary ignition wires and Parking Light
wire locations and colors.
https://cdncontent2.idatalink.com/corporate/Content/Manuals/DL-TL4/ADS-AL(DL)-TL4-EN_20120920.pdf
The DB-ALL does not handle the locks and factory alarm, so those will have to be hard-wired from the Avital to the RAV4.
The DB-ALL flashed with 401.TL4 v1.15 does the transponder bypass and other things. Here is a link to the install guide :
https://www.xpresskit.com/DocumentDownload.aspx?documentid=7734&productid=461&firmwareid=2727
Check on Page 2 for exact features supported.
------------- Soldering is fun!
