Melted Volt Meter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=141259
Printed Date: May 12, 2026 at 4:25 PM
Topic: Melted Volt Meter
Posted By: cesna12
Subject: Melted Volt Meter
Date Posted: May 08, 2016 at 7:00 PM
I have wired a duel battery system. Very basic with a solenoid (see Diagram). I have also installed a dual volt meter to keep an eye on both batteries. For some reason The Aux battery volt meter circuit board smoked. I'm not sure if it's something I did or was there a failure in the gauge unrelated. There is a Air compressor directly wired to the Aux battery Is it possible this is my Issue? I understand I will only get separate volt readings when the solenoid is in the open position.
posted_image
