Remote Wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15530
Printed Date: May 11, 2026 at 8:40 PM
Topic: Remote Wire
Posted By: midnightscape
Subject: Remote Wire
Date Posted: June 27, 2003 at 1:04 PM
Can anyone help a car audio newbie? I'm installing a amp/sub and don't know where to hookup the remote wire. No preamp outputs on the head, no dedicated remote output on the head, found a 12V dedicated and a 12V switched should it go to one of these?
Thanks in advance.
Posted By: auex
Date Posted: June 27, 2003 at 3:07 PM
Just use an accessory wire as the turn on lead, switched power for the radio or ingition wire. As far as rca outputs you will either have to wire a loc or use high level inputs on the amplifier if it has them.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: jamielong
Date Posted: June 30, 2003 at 2:36 AM
I'm also a newbie do I need to run my power lead off the battery or can it be done from inside of the cabin?
Posted By: xetmes
Date Posted: June 30, 2003 at 6:33 AM
No gotta run it from the battery
Posted By: ezridr
Date Posted: July 03, 2003 at 9:38 PM
and make sure you use a fuse or circuit breaker at the battery when running your amp power wireposted_image
My mechanic told me, "I couldn't fix your brakes, so I made your horn louder"
