Messed Up Battery?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=15859
Printed Date: May 12, 2026 at 4:57 PM
Topic: Messed Up Battery?
Posted By: Wantofok
Subject: Messed Up Battery?
Date Posted: July 04, 2003 at 2:15 AM
Ok, here's the problem...I was installing my brand new Yellow top when I accidently touched the neg. post of the battery w/the wrench as I was tightening the poss. post. and I created a spark which melted a piece off of the neg post and sent the wrench flying out of my hand. Not a very pleasant experiance. posted_image
I'm worried that I might have damaged something internally or something else in the battery...I don't know. Someone please help me out hereposted_image I'm not sure on this but, I think that I could also hear a strange noise coming from the poss. post right afterwords which lasted a couple of minutes. Also, is there any way to fix that chunk of post which I melted off?
Posted By: MAXST
Date Posted: July 04, 2003 at 12:49 PM
you have to buy new post..and get a post puller..But there isnt anythin wrong with the post that way. all you did was arch it. It shouldnt have done anything..i have done it lots of times b4.
I need quality equipment, feel free to donate.
Posted By: cool_greg
Date Posted: July 04, 2003 at 2:12 PM
sounds like the noise you heard may have been the battery acid boiling, it will do that when the battery is shorted out, it should be ok otherwise
Just a Guy, Wiring up those Vehicals
Gool_Greg
Posted By: MAXST
Date Posted: July 04, 2003 at 10:29 PM
also you should test it..make sure your fully charged b4 u reconnect...or else it wont go to full.
Posted By: Wantofok
Date Posted: July 07, 2003 at 2:40 AM
Thanks for the input...the battery has been working fine so I'm guessing no harm done :) Maxst, by saying it won't go to full do you mean as in never or until I hook it up to a charger?
Posted By: MAXST
Date Posted: July 07, 2003 at 4:56 PM
Just charge it to full charge b4 u install it.
i think since it might be lower than full charge the system will recognize it as a full charge...to a limit. i think there is a cut off for that to happen. so then you might not get a full battery and possibly shorten the life of the battery.
Posted By: Basscoholic23
Date Posted: July 28, 2003 at 11:44 PM
what happens to the life of a battery that gets jump started 2 times with a 24 month life span? I've had ppl blaming our shop for batteries going dead on brand new and almost brand new cars. One of my friends had a an intersting point on this.
Posted By: Big Purds
Date Posted: July 29, 2003 at 2:12 AM
a yellowtop or a generic run of the mill everyday 12V battery?
