how to remove an emblem?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=16307
Printed Date: May 13, 2026 at 12:33 PM
Topic: how to remove an emblem?
Posted By: Vivian
Subject: how to remove an emblem?
Date Posted: July 14, 2003 at 8:13 PM
Does anyone know how to remove an emblem or logo at the back
of a new car? I  removed the upholstery cover to see if it's just a screw type
unfortunately, it's not.. Looks like it was stick or grind to the panel of the car...
Any suggestion on how to get rid of it and not damage the car?
 than'x in advance! "  And More Power to the 12volt's guys"
Posted By: moofthadogg
Date Posted: July 15, 2003 at 6:57 PM
Yep, Its probley held on there with sticky 3M tape material like on most honds/ acuras. If so you can take some fishing line and run it behind the emblem, using a back and forth motion as you slightly pull down on it. Then use some goo gone to get the extra sticky off.
Posted By: Vivian
Date Posted: July 15, 2003 at 7:27 PM
than'x but I think it's more complicated than that..
There's a metal plate grinded behind the panel of the emblem which I think is the one holding it... I tried to move it a little bit but I'm afraid I might
damage the exterior paint of the car.. What do you think?
Posted By: auex
Date Posted: July 15, 2003 at 8:27 PM
What kind of car is it? Some of the emblems have a guiding pin and a hole in the body.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: cool_greg
Date Posted: July 15, 2003 at 8:42 PM
heat it up with a heat gun, that will loosen the double sided tape to the point to where you can virtually peel it off.
Just a Guy, Wiring up those Vehicals
Gool_Greg
Posted By: Vivian
Date Posted: July 15, 2003 at 9:53 PM
The car is actually Hyundai Sta Fe 4WD 2002 model.. And your'e right, normally it has a guiding pin behind the back of the panel which I think is much easier to remove isn't it?  but this one is a little different, I don't see one?
Pls.help!
