Help Needed
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=17696
Printed Date: May 06, 2026 at 12:54 PM
Topic: Help Needed
Posted By: demonhound69
Subject: Help Needed
Date Posted: August 16, 2003 at 11:18 PM
I Was connecting my head unit to my 95 civic ex, and i blew my radio fuse and lost all power in the radio area, and the clock went real dim. I put a new fuse in, and i still have nothing. I have done alot of car stereos, and have had problems similar to this, but ive always been able to work with those. If someone can help me, id appreciate. Thanks.
Posted By: wizzle
Date Posted: August 17, 2003 at 2:59 AM
is there a fuse panel in the engine compartment?  there should be another fuse there that will be blown.  Sometimes the clock and radio are on the same curcuit, so i would check the engine.  If you checked there already, there should be another fuse panel under the steering will or in the drivers side kick panel
Date Posted: August 17, 2003 at 8:20 AM
I checked both fuse panels, and nothing is blown. I blew the radio fuse but replaced that and it still doesnt have power for the radio and the clock is still dim.
Posted By: samdub
Date Posted: August 20, 2003 at 10:16 PM
it could be security coded if that is the case you will may need the dealers help check your owners manual
