Need:Timer/Delay diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=18792
Printed Date: May 04, 2026 at 11:02 PM
Topic: Need:Timer/Delay diagram
Posted By: Fox4dr
Subject: Need:Timer/Delay diagram
Date Posted: September 11, 2003 at 11:24 AM
The temp in my car climbs about 20 degree's after shut down and I 'd like to set up a delay or timer to keep the electric fan running for about 2-3 minutes. I know this helps as I do this by turning it back on to run after shut down. This is not a factory deal,fan is controlled by an in the rad probe,switched by relay and obviously controlled by  run 12v .
Thanks a heap
Bill
Posted By: Rox0rz_Carz0rz
Date Posted: September 12, 2003 at 10:45 PM
probably the easiest would be to use a big-asses car-audio capacitor (perhaps a 2 ferad), just make sure you use a diode to keep it from discharging into any other system but ur fan.
Not sure if this'll accually work, just i theory that popped into my head as i'm sitting here deprived of sleep posted_image
Did Anybody Order A Pizza?
Posted By: xetmes
Date Posted: September 13, 2003 at 6:09 AM
i think it could easily be done with a transistor, capacitor, and some resistors... maybe if i get some time ill draw something up
Date Posted: September 13, 2003 at 10:03 AM
that makes more sense, but i'm lazy. - lol
