Reprogram passlock II?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=19925
Printed Date: May 06, 2026 at 3:38 PM
Topic: Reprogram passlock II?
Posted By: IRNOTSLOW
Subject: Reprogram passlock II?
Date Posted: October 10, 2003 at 4:55 PM
Is this possiable?
2002 chev silverado
how about this cutting yellow wire taping the engine side into the orange and re-program passlock as follows:
Antitheft system consists of a hall effect switch in the ignition lock assembly that produces a calibrated voltage signal as the lock cylinder is turned. The voltage signal is used by the ECM antitheft system. If no or incorrect voltage is signaled, the ECM will shut off. When the mechanical ignition switch fails, it must be replaced along with the hall (Passlock) sensor. The system must be programmed after replacing the assembly.
 To reprogram:
1) When trying to start the engine, it will start and stall.
2) Leave the key on for 10 minutes while the “security” light flashes.
3) When it stops flashing, repeat steps 1 and 2 three more times.
By doing this have I permanatly disable paslock, to read its own restance, by avoiding the key wiring?
i thank you in advance
PS can I get the wiring diagram for these trucks 2002 CHev burb and silvrado
irnotslow
Date Posted: October 10, 2003 at 4:57 PM
oh yea onw more question (for now)   Does GM have a bank of resister they use for paslock II? or is it all generated from the cylinder?
thanks
irnotslow
Posted By: Crush
Date Posted: October 16, 2003 at 2:28 PM
put your questions in the security section and you may get an answer
why am i the only one in the world that has that problem?
