additional horn installation
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=21827
Printed Date: May 15, 2026 at 3:44 AM
Topic: additional horn installation
Posted By: indycar02
Subject: additional horn installation
Date Posted: November 23, 2003 at 11:01 AM
I've purchased a pair of horns I'd like to add on to my OEM horns on a 2002 Ford Ranger. I hooked a hot wire from one of the OEM horns and conntected to a "Y" connector. When I plug the wires into the add-on horns it only works if one add-on horn is hooked up. When I hook up the second horn, all the horns just click like there not enough juice to activate. Do I need to hook up an additional relay and if so, what's the procedure?  Thanks
Posted By: ck auto
Date Posted: November 23, 2003 at 4:27 PM
hi you need to add a relay.i would wire it to the factory trigger in the collumn which is yellow and green (-) at the collum be careful when testing they are run with the airbag wires.
pin 85 to yellow and green in collumn
pin 86 to 12 v
pin 30 to 12v
pin 87 to the additional horns
make sure and fuse your 12 volt connection
good luck
kirk
