98 bonneville IAT sensor
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22338
Printed Date: May 14, 2026 at 5:27 AM
Topic: 98 bonneville IAT sensor
Posted By: alexthepunk
Subject: 98 bonneville IAT sensor
Date Posted: December 04, 2003 at 12:29 PM
i need help finding the IAT sensor on my intake, i bought a chip to replace it, and i cant figure out where it is..thank you
Posted By: sparkie
Date Posted: December 04, 2003 at 9:41 PM
It's located in the air intake tube for the engine. It usually has two wires on it ( tan and RED / black or just black)
sparky
Posted By: auex
Date Posted: December 04, 2003 at 9:53 PM
Man I hope you didn't spend much for a resistor, because that is all that "chip" is.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: December 05, 2003 at 12:23 AM
lol. i spent 30 cents at radio shack..lol.. when i put it in. the check engine light comes on,, is that bad? any words of wisdom??
lol
thanx
Posted By: auex
Date Posted: December 05, 2003 at 2:53 PM
It sounds like the resistor that you bought is out of the normal range of what that sensor would be looking for.
Date Posted: December 05, 2003 at 2:58 PM
ok.. have a 100K resistor, any suggestions,,
as always..
thanx for the help
Posted By: Teken
Date Posted: December 05, 2003 at 4:13 PM
If the vehicle throws a MIL code while the vehicle is operational. Depending upon the vehicle year, make, and model.
The vehicle will go into *limp* mode and will never allow the engine to achieve maximum speed.
It is basicly like a rev limitor, but in other vehicles such as the Northstar engine, the ECU will actually drop two cylinders from operatiing, and run on only the last 6.
For Honda / Acura's the MIL will prevent the vehicle which is so equiped with VTEC adjustments to not allow the secondary cam lobes to lock / engage.
At the end of the day, its all about air, fuel, and combustion (compression / displacment) pressure that will yeild higher HP.
You will not see any gains with the resistor.
Regards
EVIL Teken...
Date Posted: December 05, 2003 at 4:23 PM
thank you, that has been most helpful
