Guidance replacing whole stereo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=2240
Printed Date: March 30, 2026 at 2:12 PM
Topic: Guidance replacing whole stereo
Posted By: monsoon-bad
Subject: Guidance replacing whole stereo
Date Posted: July 26, 2002 at 7:30 AM
I am replacing the whole Monsoon POS 200 watt system on my 02 Passat.
The new speakers are 2 pairs of Infinity Kappa's 60.5cs components whereby each will get 70watts rms.
Do I need to replace the stock speaker wires to handle the higher power. I think they're 18 guage.
Posted By: Velocity Motors
Date Posted: July 26, 2002 at 4:45 PM
It would better to replace them, but not necessary if you don't want to run new wires. There is a factory amplifier in vehicle as well that you have to bypass if your wanting to use the existing wiring. Otherwise you can pull the amp out as well.
Date Posted: July 26, 2002 at 6:16 PM
The factory 8ch 200w amp is coming out. In it's place are 2 Kenwood 4ch bridged to o/p 70w rms to 4 crossovers and then to the factory speaker wires.
Date Posted: July 26, 2002 at 9:43 PM
You might as well install new wiring seeing that you will have to anyway if you are adding 2 new amplifiers to the speakers. Without the factory amplifier the speakers will not work with the deck.
Date Posted: July 27, 2002 at 8:51 PM
I'll also be replacing the Monsoon speakers with 60.5cs Infinity Kappa components. The crossovers will be approx where the Monsoon amp was.
Date Posted: July 27, 2002 at 9:59 PM
Just make sure that the speakers are getting enough power otherwise they will be a disappointment to you. It sounds like you have a good set up....... any plans for a sub ??
Date Posted: July 28, 2002 at 12:18 PM
Just an Infinity basslink w/ remote level control. Power will be 4ga fused to a dist box where 8 ga will go to each amp. Head unit will be a double din Kenwood dpx-mp4030 am/fm/cd/cass/mp3 player (great specs).
Date Posted: July 28, 2002 at 12:33 PM
Good luck witht he install and the set up will sound better than the stock.... gauranteed !!
