97 Dodge Intrepid
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=238
Printed Date: April 02, 2026 at 2:51 PM
Topic: 97 Dodge Intrepid
Posted By: CSanders73
Subject: 97 Dodge Intrepid
Date Posted: April 04, 2002 at 10:08 PM
I am transplanting a system from another car into this 97 Intrepid. I need to run the 4 gauge power wire to the amps in the trunk, where can I run this wire through the firewall? Every other car I have worked on I ran it through an electrical wiring boot, I can't find anywhere to do that on this car. I do not want to drill/grommet unless there is no other option. If anyone has done an install on one of these I would be interested to hear where you ran the power wire.
Also where can I find the correct box dimensions for an older pair of subs (4ohm 400w Boston Acoustics Rally Series...had them since '95) with no manuals, is there a web site? I want ot get the most out of these I have never had to build a box that was for a trunk (I have always had hatchbacks or SUV's) I know I don't want a bandpass, what is better in a trunk...sealed or ported?
Uh....I think that's it. Any help would be appreciated!
Date Posted: April 05, 2002 at 1:10 PM
I got a copy of the speaker manual from the Boston web site.....still would like info on running the power wire though.
Posted By: the12volt
Date Posted: April 06, 2002 at 8:43 AM
Hi CSanders73, there is a large grommet surrounding the speedometer cable high in the dash above the accellerator pedal. You can use a 30" phillips to push a snake wire through it from the engine compartment if necessary.
You didn't mention which Rally Series woofers you have, but I did find a link that may be helpful here:  https://www.bostonacoustics.com/tscarpm.asp  or you can try contacting Boston Acoustics here:  https://www.bostonacoustics.com/Switchboard.asp
As far as which enclosure type is better is a matter of opinion....my preference much of the time is a sealed enclosure, but the only opinion that matters regarding your vehicle is yours.
the12volt
Date Posted: April 16, 2002 at 1:20 PM
Thanks for the advice on running the cable.
I just kept the subs in the sealed box I already had built (the subs need 1.56cf, the box was 1.58cf added some extra bracing...I'm in buisiness). They hit harder than ever!
Thanks again!
