sound staging ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24846
Printed Date: May 14, 2026 at 11:04 AM
Topic: sound staging ?
Posted By: Clean Install
Subject: sound staging ?
Date Posted: January 18, 2004 at 11:05 PM
I am wondering when a judge is judging a SQ vehicle, what is he looking for as far as sound? I feel that in a vehicle the music should come from all around and you should not be able to tell where the sound is coming from.... is that correct at all? A man came in to a local shop the other day and thats how I described it, he thought completly different... he said that its like a concert where the music is in front of you and you and you are able to tell where the music is coming from which one is right?????? I have my car setup to where music comes from all around not just from in front ( I dont think that, the music coming from in front sounds that great ) What is everyones thoughts on a great sounding system?
Date Posted: January 21, 2004 at 8:24 PM
anyone have any thoughts on this subject
Posted By: DYohn
Date Posted: January 22, 2004 at 2:23 PM
A "proper" soundstage will trick the ears into locating the source of the sound from in front of the listener. The perfect sound stage would seem to originate from the center of the windshield, with proper left and right imaging for stereo effects. Any rear sound should only be fill or echo effects. What you describe as "coming from all around" may be fine for the average listener, and if it sounds good to you then go for it, but in SQ competition that would be judged as lacking proper sound stage imaging, regardless of how clean and accurate the reporduction might be. This link might be interesting to you: https://www.mecacaraudio.com/sqrules.php
Date Posted: January 22, 2004 at 10:08 PM
thanks for the link, I've read it a little, does the site give any suggestions on proper soundstaging? thanks again DYohn ------------- If we learn from each success and
each failure, then we can improve ourselves
Posted By: markcars
Date Posted: February 26, 2004 at 9:50 AM
In addition to what was said, I have a few more thoughts to share. First, there are two types of sound systems.
4 channel stereo which is really 2 channels. You can increase or decrease the percentage of sound to either
front doors or to rear doors (Fader). As per sound channels, on a 4 channel amp, there are 4 separate "channels" but
only 2 recordings for each side, Left and Right. Then there is surround sound whereby you can use only 2 channels/speakers
and the signal processor makes an effect of "depth" by processing the sound accordingly. Then there is true surround,
where your amp is a true surround sound amp with 4 separate channels or even 5 (1 extra for the sub). In order to hear true surround,
your recording (most DVD movies have it) must have 4 (or more) separate channels recorded.
Personally I do not like the fake surround sound where 2 channels make you feel like there are 4 or more sources, but thats just my preference.
To have a good system, you should not be able to tell if the source of the sound is coming from one single area
but you should feel/hear it as if you are in the midst of the action/sound sources. In case someone asks you why
we need 2 speakers for left and right but only 1 subwoofer, the reason is very low frequencies are non-directional
meaning you cannot tell where the sound is coming from so it doesnt matter where you place the subwoofer, to the
left or right. Higher/mid frequencies are directional, meaning you can tell where they're coming from, hence you got
to have 2 sources at least, at left and right. Lastly, the listener's position in respect to the speakers is also important. The same system will sound different from different listening angles. Hope i helped. If anyone has more ideas, I would like to read them too.
Posted By: Chad7n7
Date Posted: March 10, 2004 at 2:24 AM
I agree firmly with markcars in his first statement about your sound originating from the center of the windshield. and any rear being solely for the purpose of "fill in" or echo, I am running my highs and mids in "mixed mono" I have two Zapco 200's one on left side and one on the right, on two sets of components, the front sets are run bridged, therefore sending close to 500 watts to the doors, and the rear are run stereo giving them about 200 watts, just as "fill in". My vehicle is used as a demo vehicle for a friend of mine's stereo shop. I have had several judges sit in my truck and ask if I had set this up for comp., but unfortunately I don't have the time to do it anymore, and therefore it wasn't set up this way for comp., but only for demo purposes and personal enjoyment, but to get back to the point, from my understanding and from talking to a few judges, I think markcars has the hammer on the nailhead.
