1996 Cavalier 2.2L Tach Problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24973
Printed Date: May 14, 2026 at 3:39 PM
Topic: 1996 Cavalier 2.2L Tach Problems
Posted By: wiggy_03
Subject: 1996 Cavalier 2.2L Tach Problems
Date Posted: January 20, 2004 at 9:53 PM
I just bought a brand new tach for my 1996 Cavalier 2.2L.  I've tried three tachs now and they all read low RPM's...like it will idle at only 500 RPM's at max and i can't even hit 3,000 RPM's with it, i'm pretty sure i got the right wire, it's the white wire from the coil pack, if i'm wrong someone please straighten me out because i can't for te life of me figure this out, thanks.
Posted By: corraudio
Date Posted: January 20, 2004 at 10:37 PM
Posted By: sparkie
Date Posted: January 22, 2004 at 3:00 PM
The correct tach wire is the white wire. It is easily accessed in the wire loom passing over the transmission on the driver's side of the engine under the air intake. It is the only white wire in the loom and heads towards the ignition module at the bottom of the motor close to the firewall. Test your other connections for the tach such as the ignition source (pink 12 gauge wire off the ignition switch) and ground. Use a clean, paint free section of the vehicle's chassis for ground.
sparky
Posted By: mikeshonda750
Date Posted: January 22, 2004 at 5:45 PM
Also... might wanna check out the tach your using... i know all of mine had switches on them to switch from 4cyl 6cyl 8cyl ... if your running a 4cyl and tach is set to 6cyl, your R's will be really low.
