Newbie Q: accessory distribution
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27684
Printed Date: May 11, 2026 at 6:59 AM
Topic: Newbie Q: accessory distribution
Posted By: max5spd
Subject: Newbie Q: accessory distribution
Date Posted: March 03, 2004 at 9:35 PM
Hi, is there a product (sort of like a distribution block) that will allow me to attach multiple 14AWG or around same size wire?  I have several devices (hardwired radar, NAV, etc) that I end up just splicing the power wire to any 12v wires that are applicable.  Ideally, I'd like to get some sort of block that I can directly feed from the battery, use a switch of some sort, and attach all my devices to without having to splice anywhere else.  Please excuse me if I'm using the correct terminology.
Andrew
Posted By: Ravendarat
Date Posted: March 03, 2004 at 10:41 PM
You can buy a simple switching block from places like canadian tire where they have one 8 gauge input and then 4 switches each with a output terminal that will accept up to 12 gauge wire. Itll run about 40 bucks canadian from what I have seen
Posted By: max5spd
Date Posted: March 04, 2004 at 10:00 PM
Sounds like what I need.  Since I live in the US, we don't have any Canadian Tire places.  I went to canadiantire.com, but I didn't see anything similar.  Have any leads?
Thanks a bunch.
Andrew
Posted By: S.I.Autosports
Date Posted: March 05, 2004 at 5:56 AM
https://www.jcwhitney.com/webapp/wcs/stores/servlet/ProductDisplay?productid=1055&catalogId=10101&langId=-1&storeId=10101
check that out, it should do what you need.  just remember to fuse your power wire as close to the battery as possible.
