1995 Oldsmobile 88 Royale ignition
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=27966
Printed Date: May 11, 2026 at 7:42 PM
Topic: 1995 Oldsmobile 88 Royale ignition
Posted By: pcfdp_grey
Subject: 1995 Oldsmobile 88 Royale ignition
Date Posted: March 08, 2004 at 10:21 AM
I have a 1995 Oldsmobile 88 Royale with the 3800 series 3.8L V-6. When I try to start the engine when cold, it acts like it's being choked and dies, The colt and temp sensor lights flicker on and off (no problems at all when the engine's warm). Could this be the problem of why it doesn't want to run cold? Suggestions on how to fix it? I have already replaced the fuel filter, the ignition coils, and the ignition relay.
------------- "God is watching us from a
distance... But that's only due to the restraining order"
Pool Cleaner Grey
Posted By: auex
Date Posted: March 08, 2004 at 10:17 PM
Problem with the distributor maybe, try cleaning the contacts? I assume it is fuel injected. I would also do a basic tuneup.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
