main power voltage drops
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28148
Printed Date: May 12, 2026 at 2:24 AM
Topic: main power voltage drops
Posted By: superxox
Subject: main power voltage drops
Date Posted: March 10, 2004 at 9:46 PM
I have an old 1987 Honda Accord.  When I try to start the car and turn the key into ignition position, the lights on the dashboard show very dim, the clock and cd player donˇ¦t even work. When I turn to the cranking mode, nothing happen.  I tested the starter wire, no voltage on it when I turn the key to the cranking mode.  Also, I tested the main power cable, the voltage is below 12V.  But the funny part is, after a long period of time, it voltage suddenly comes back to normal 12V, but the car still doesnˇ¦t start and the voltage drops again.  I tested the battery, which is fine.  Does anyone know what can cause this kind of rare problem?
I am not sure if itˇ¦s okay to post this kind of question on the forum, but I really appreciate for any help.  Thanks!
Posted By: superxox
Date Posted: March 11, 2004 at 11:30 AM
sorry about the post above, dont know why it shows html code, but here is what i want to post...
I have an old 1987 Honda Accord. When I try to start the car and turn the key into ignition position, the lights on the dashboard show very dim, the clock and cd player don't even work. When I turn to the cranking mode, nothing happen.  I tested the starter wire, no voltage on it when I turn the key to the cranking mode.  Also, I tested the main power cable, the voltage is below 12V.  But the funny part is, after a long period of time, it voltage suddenly comes back to normal 12V, but the car still doesnˇ¦t start and the voltage drops again.  I tested the battery, which is fine. Does anyone know what can cause this kind of rare problem?
I am not sure if itˇ¦s okay to post this kind of question on the forum, but I really appreciate for any help.Thanks!
