93 Buick Century Power Windows
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=28778
Printed Date: May 12, 2026 at 11:12 PM
Topic: 93 Buick Century Power Windows
Posted By: Akeener
Subject: 93 Buick Century Power Windows
Date Posted: March 21, 2004 at 12:53 PM
HI Everyone!  I need some help from someone. I didnt find what I needed in the wiring section.  Here is my problem.  My right side power windows do not work.  I took off  the door trim and unhooked the connector.  I took a volt reading and came up with nothing.  I also ohmd it out and there was continuity between the two wires going to the window motor and also between the 5 other wires in the connector. I am assuming this is bad but am not sure.  I thought maybe I had a bad relay or module, but i dont know where to locate them to test them.  Can someone please help? Thank you very much.
Adam
Posted By: Akeener
Date Posted: March 21, 2004 at 12:55 PM
Actually Its for a Regal. Im sorry :)
Posted By: billybrent
Date Posted: March 24, 2004 at 10:12 PM
    One of  your switches is not making a good connection and is not allowing either of the two switches to work
   I know this sounds weird but take out your switches and clean them with  carburator cleaner and re-install
   them .  Chances are that the connection points in the switches are corroded over and just need to be cleaned.
    I could be wrong -but it is an inexpensive first test and I tried this on a truck and it worked.
   Billy
187
