Install digital compass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=29802
Printed Date: May 13, 2026 at 10:27 AM
Topic: Install digital compass
Posted By: volvo04
Subject: Install digital compass
Date Posted: April 06, 2004 at 9:58 AM
I am hardwiring a Wayfinder digital compass to a 04 Volvo. The hardwire consists of a hot wire with fuse and ground wire. Where is the best place to hook into the power supply of the car apparently so power is constantly to the unit? Being a dummy on electrical systems, I assume the ground can just be attached to any metal bolt that is attached to metal of the car. Thanks.
------------- Volvo04
Posted By: Teken
Date Posted: April 12, 2004 at 6:28 PM
You can wire the Wayfinder to the cigerette lighter for a constant +12 VDC. The ground point should be varified with a DMM, because some vehicles use plastic inserts to seperate partitions in the LCP or in the cowl.
Anytime you see a OEM area with a ground plane attached, that is a good indicator that the area is sound for use.
Regards
EVIL Teken . . .
