Jeep Grand Cherokee 99
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31229
Printed Date: May 15, 2026 at 11:33 PM
Topic: Jeep Grand Cherokee 99
Posted By: Paintballislife
Subject: Jeep Grand Cherokee 99
Date Posted: April 28, 2004 at 7:02 PM
Stupid stock infinity crap, what a pain in the ass. Ok heres the deal i need some epert advice, and this is kinda the place right? alright, first, i wanna keep the stock head unit despite my original intentions. So, yesterday i got infinity component the 6.5" well i wanted the tweeters up front (makes sense right) so the 6.5"s are in the rear doors, then i got 3 way pioneers 225 watts in the front. I couldnt cash out or the time for a new amp, so im using the stock POS 2 ohm infinity 180 watt. Now, im planning on gettin a cadance 4 channel. From what ive gathered, the amp is a 6 channel infinity.  Hence my dilemma. 6.5"s are on a crossover, but the tweeters are technically with the wiring in the back and the 6x9"s are only pushing lows cause the amp. Now if i get this cadance 4 channel, i want the tweeters up on the front channel, if its worth it, but i know i really dont wanna run them off the pionners. If im downsizing to a 4 channel what am i gonna do with the wiring.
SO quick recap tweeters:
 Stock infinity 180 watt amp 2ohm 6 channel pushing pioneers 6x9"s running lows in the front. infinity component with crossover 6.5"s are in the rear doors, tweeters are in the front. How am i gonna run the system off a 4 channel with the best sound?
Posted By: Chad7n7
Date Posted: May 02, 2004 at 10:39 PM
you should only need four channels form what I am reading, you have 6X9's in front doors, that's 2 channels, Then you have Infinity component set, that should be the remaining two, because you run the tweets and mids to the crossover network outs, and you only need one input for each side, so thats only four channels there, unless I am misunderstanding the way you have it setup.
