amperage meter schematic needed
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31369
Printed Date: May 16, 2026 at 6:38 AM
Topic: amperage meter schematic needed
Posted By: disco-stu
Subject: amperage meter schematic needed
Date Posted: April 30, 2004 at 11:34 PM
I have 2 power meters for my car audio but after a amp meter for it too so i can see the current draw all the time, pref digital,
if anyone knows of a circit or schematics please leave a link.
thanks in advance.
Stu
Posted By: Mad Scientists
Date Posted: May 02, 2004 at 12:41 PM
 Not sure if you're looking for a temp installed meter or a permanent one; how much current are you expecting to draw and where do you want to mount the display?
 Regards,
 Jim
Date Posted: May 02, 2004 at 11:16 PM
Basically i want to add this digital readout to my main power in 0 gauge line so i can see how many amps my system is drawing.
Date Posted: May 03, 2004 at 5:15 PM
 Where do you want the display mounted?..
How much current are you expecting to see?.
Is this to be a permanently mounted meter?
 Jim
Date Posted: May 03, 2004 at 7:42 PM
In my boot i have 0 gauge cable comming in to a disroblock with a volt meter built into it, then 2 4 gauge cable out , i want it just before the distro block so i can see what the total current my system is drawing.
not sure, a 3 digit 7 seg display should be good enough, think the amperage would be round 60 - 100.
yes this is to be prem mounted in a perspex box i will make.
Thanks for your help.
Date Posted: May 04, 2004 at 9:05 PM
^^^^^^^^^ bump
Date Posted: May 05, 2004 at 5:02 PM
 Look into using a shunt to measure that amount of current.. best places to look would be a motor home parts company, or something for automotive charging systems.
 Regards,
 Jim
Date Posted: May 06, 2004 at 4:42 AM
Any ideas where to get a schematic for it?
thanks
