Spal Power windows
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=31823
Printed Date: May 17, 2026 at 12:02 AM
Topic: Spal Power windows
Posted By: tommer2
Subject: Spal Power windows
Date Posted: May 08, 2004 at 6:08 PM
Hi guys,How about some help? I'm wiring up my Spal window kit. The instructions say to run the 12V wire to the ignition side of the ignition relay block.Where the heck is that????????????????It shows the red 12V wire going to the battery and a ignition wire. Any thoughts would be a BIG help!!!!Maybe there is an easier way to hook this up. Also should I use a relay somewhere on this?Thanks in advance.
Thom
Posted By: Greg S
Date Posted: May 11, 2004 at 11:07 AM
What they are talking about is the main ignition input line to the fuse block.  You can get this off of the fuse block, ignition harness or my favorite way, if the car had a power window option from the factory then you can tag in to the fuse block where the stock window line output would be and just insert the appropriate fuse or circuit breaker in the fuse block.  This is how I wired up the window kit in my car.
Greg Stoddard
