Door Trigger
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3205
Printed Date: April 01, 2026 at 8:28 AM
Topic: Door Trigger
Posted By: Wingman21
Subject: Door Trigger
Date Posted: August 30, 2002 at 2:32 PM
I'm planning to buy two neons to put under my dash and I would like pretty much them to light up when I open any of the 2 front doors. I know this question has been asked a lot of time, but I'm a newbie for electrical stuff in my car and I just want to do it right ! So, will it required a check on each door or can I use for exemple the door open icon on my dashboard !?
By the way, I got an alarm system ... I dont know if that could help !
Posted By: naughtydog
Date Posted: August 31, 2002 at 8:10 AM
Just pick up the negative switching door switch wire and use this to trigger a relay. You can then switch a negative or positive from the relay to control the neons.
eg.
Connect terminal 30 to negative
terminal 85 to your door switch wire ( switced -ve)
terminal 86 to  positive 12V
terminal 87 to the negative wire of your neon
Connect the positive wire of your neon to positive12V
Thats it...
Naughtydog
Date Posted: August 31, 2002 at 10:59 AM
eg.
Thats it...
Naughtydog
Does the negative switching door switch wire control both the fronts doors ? 'Cause I want my neon to light up whenever one of the two fronts doors open. Also, if I wanna have a switch that can light them up no regard to my door, can I just bring another wire to pin 85 from the ground (negative) with some diodes ? Also, that circuit is for negative door trigger I suppose ... If I have a positive trigger, I just use the ground instead of the 12V on pin 86 and inverse 85 and 86 (85: 12V, 86: ground) ? By the way I got a Mazda Protege 2002 !
Posted By: mobiletoys2002
Date Posted: August 31, 2002 at 11:02 AM
yep that is correct wingman .
Date Posted: August 31, 2002 at 11:05 AM
oh by the way your wire is BLACK/ blue drivers kick panel and it is a negative. This wire will control all doors so whenever any door is open the neon will come on.
Date Posted: August 31, 2002 at 6:25 PM
Great ... thanks a lot guys !!!
I let you know when I'll get my neons !
Posted By: scorpion_1203
Date Posted: November 01, 2002 at 10:39 AM
hi Wingman21 did u get it to work im about to try to tackle the same thing im putting my lights under my seats though? I want my light to do the exact same thing ...if the doors are closed i want to be able to cut them on with a switch....i think i understand the relay part i've been reading the tutorial on here....but the diodes  how would all that work?    Any help would be greatly appreciated.
Please contact me at scorpn_1203@yahoo.com   Where can i buy relays and diodes?? Radioshack??
I have a 95 mustang convertible
thanks
Scorpion_1203 :)
