Will an Amp help?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=33305
Printed Date: May 16, 2026 at 7:33 PM
Topic: Will an Amp help?
Posted By: kaajonman
Subject: Will an Amp help?
Date Posted: June 04, 2004 at 3:48 PM
Hello,I have a 2000 GMC Sierra.I put Polk components in the doors and Infinity 4x6's in the back.They sound great with the Delco factory stereo.I changed the receiver and put in a Kenwood mp425 so I could play mp3's.The sound is not as good as I expected, in fact the factory stereo is better.Would an amp make any difference? Thanks.
Posted By: mikedawg
Date Posted: June 04, 2004 at 9:05 PM
not really. usually the stock mids are blown in the first two years. check first to see if you blew them.  second, the stock speakers are usually less than one ohm so they get the most out of the stock deck without more power. and check to see if the speakers have a common ground. if they do, youll need to redo the wiring. common ground meaning the positive is the only wire to get sound and power.
always looking for new info and willing to give it
Posted By: stevdart
Date Posted: June 04, 2004 at 10:40 PM
Yeah, the factory head sounded better because it was made to run the stock speakers without an external amplifier, probably with a higher output voltage than the new Kenwood has.  Your new receiver needs an amp, it was designed to be amplified, and it has RCA outputs to make hookup fairly simple.  Start shopping for a 4 channel amp.  It'll bring those new speakers to life.
Posted By: mikedawg
Date Posted: June 04, 2004 at 10:51 PM
well the kenwood receiver should give more power to the speakers, so im thinking that he has a premium system and/or the speakers have a common ground. i would just buy new mids and tweets
Posted By: stevdart
Date Posted: June 04, 2004 at 11:40 PM
mike, he posted that he put in new speakers and that the system is Delco factory.  The 2000 GMC has floating ground.
Posted By: mikedawg
Date Posted: June 05, 2004 at 9:54 AM
oh sh%t,  i forgot about that. well thats weird than. i would just suggest checking the polarity of the speakers, and making sure youre  not turning up the bass too much on the deck. of course an amp would help. it creates a high pass and allows you to turn up the volume higher without distortion.
Posted By: forbidden
Date Posted: June 05, 2004 at 6:53 PM
I would take the Kenmore back out and replace it with an Eclipse and you will hear a drastic imnprovement in sound. After that a good 50w x 4 rms amplifier is in your future. Ignore the wattage claim on the front of most cd players, they will make that much power if they get struck by Lightning. There is a huge difference in cd players, especially between one that is built to sound good and one that is built to catch your eye.
Posted By: Manoftools
Date Posted: June 05, 2004 at 8:46 PM
I am suprised to hear you say that the Eclipse would offer a major improvement over a Kenwood radio.  In my experience Kenwood offers excellent sound quality, and Eclipse has not been as consistent with sound quality.  But then again, that is just my experience and opinion.
Posted By: stevdart
Date Posted: June 06, 2004 at 11:27 AM
I think ya gotta take Kenmore more seriously...aren't they the ones with the exclusive "PhatNoise" music management software?          posted_image
Posted By: mikedawg
Date Posted: June 06, 2004 at 11:39 AM
i like them both. theyre the only head units i use.
