RF CD Changer in '97 Sable
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=3447
Printed Date: May 01, 2026 at 6:05 AM
Topic: RF CD Changer in '97 Sable
Posted By: macville
Subject: RF CD Changer in '97 Sable
Date Posted: September 08, 2002 at 5:56 PM
I have been trying to install a SPS 6 disc RF cd changer in my 1997 Sable (With Mach audio sound system) and finally got the changer wired in correctly today (I'm pretty sure.) However, whenever the LCD controler is pluged into the RF unit the atnna. stayed down until I unplug it (plus the controler doesn't seem to work...) So...what do I have wrong? Is it that my controler is busted and needs to be replaced, or do I have something wired incorrectly?
Thanks,
Matthew Rogers
Posted By: cpgoose
Date Posted: September 09, 2002 at 6:13 AM
It's been a while, but don't you have to disconnect the antenna from the radio and plug it into the RF adapter....and then plug the RF adapter's plug into the radio's antenna input?
Not sure if that's what you did, but if you didn't that might be the problemo.
