Head Unit Manual Switched Power
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=34847
Printed Date: March 28, 2026 at 3:10 AM
Topic: Head Unit Manual Switched Power
Posted By: jd68
Subject: Head Unit Manual Switched Power
Date Posted: June 30, 2004 at 11:25 AM
Wondering if anyone has delt with making a simple toggle switch for operation of a head unit withour having to use the igition switch and what to look out for when wiring it, any input in apprciated JD
Posted By: raydawg357
Date Posted: June 30, 2004 at 2:39 PM
That's simple. All you have to do is run a toggle switch between the switched power wire. You will still need to connect the constant power to maintain the memory.
------------- Do it right the first time
Posted By: jd68
Date Posted: July 01, 2004 at 1:54 PM
so would you use the pre-ingition power wire, the memory power lead, or a seperate aux wire to place the toggle, im wondering considering the load on the different runs and how it will affect the car and radio
Posted By: Mr.Swifty
Date Posted: July 04, 2004 at 1:04 PM
I do this in alot of the show cars, a toggle switch hooked up to constant power, works fine, I just put a 6amp diode inline so when you turn on the switch, the power only goes to the deck, and not the rest of the ACC circuit
Posted By: jd68
Date Posted: July 05, 2004 at 9:14 PM
Thanks Swifty,
tThats exactly what I needed to know, much easier than a I originally thought. additionally have you done this to other interior components? I only need to wire the radio for it, but was wondering about a few cars ive seen with those features including timed and switched setups. anyway thanks for putting me on the right track. oh and just to clear up one thing, the constant power can be the yellow lead before the head unit constant fuse and brought over to the acc lead? or used a seperate run all together?
JD
