Fuse box power source for Power Outlet
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=35390
Printed Date: May 14, 2026 at 4:41 PM
Topic: Fuse box power source for Power Outlet
Posted By: BEATBOYY
Subject: Fuse box power source for Power Outlet
Date Posted: July 11, 2004 at 6:57 AM
Hey All:
In order to install a neon license plate and washer lights I decided to get a Quick Connect Power Outlet by Bell. It will allow me to hook up 6 direct wire compnents and control them with a switch. Its a 2 wire connection +/- and the directions say to hook up the positive wire to an "Open ATO Fuse Socket" in my fuse box. The problem is, I cant find anything "open" in the fuse box of my 2002 Toyota Highlander. Does anyone know where I can find it or do you have an alternative installation?
Posted By: Teamrf
Date Posted: July 11, 2004 at 5:17 PM
You should use a relay and hook it up under your dash to a constant 12volt source with a toggle switch on it.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: BEATBOYY
Date Posted: July 12, 2004 at 12:23 PM
What about connecting the Power Outlet to a constant 12 volt source? Would that also work? Or would I need a relay?
