2002 Lincoln Navigator fusebox
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=39477
Printed Date: May 15, 2026 at 2:44 AM
Topic: 2002 Lincoln Navigator fusebox
Posted By: Felix JR
Subject: 2002 Lincoln Navigator fusebox
Date Posted: September 21, 2004 at 11:22 AM
 i need help with finding  the fusebox for a 2002 lincoln navigator, i've checked the owners manual and that books wrong. I need to know where exactly that box is, i'm trying to hookup a constant and a ignition. thanks
Posted By: boxmaker85
Date Posted: September 21, 2004 at 11:44 AM
Are you lookin for the main fuse box?  Couldn't exactly tell you exactly were but majority of boxes are under the hood normally near the battery (usually behind the bat toward the cabin).  The other fuse areas are under the left side under the stearing wheel and sometimes on the right side of the glove box.  Check those places.  Could be other places, but those are some common ones.  Also try contacting a Lincoln dealership that services cars and they should tell you.  But then again ford makes it, so...good luck.
Posted By: Felix JR
Date Posted: September 21, 2004 at 5:01 PM
Well I found the damn fuse box. I talked to someone at lincoln that knew what they were talking about  and they told me that the fuse box can be found in the passenger side toe kick panel. Boxmaker85 thanks for your reply.
Date Posted: September 21, 2004 at 8:17 PM
good luck   posted_image
