Head Unit Issues...
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=416
Printed Date: April 02, 2026 at 11:46 AM
Topic: Head Unit Issues...
Posted By: KB1EWE
Subject: Head Unit Issues...
Date Posted: April 22, 2002 at 9:31 PM
I just changed all the speakers in my '98 Lincoln Navigator to Audiobahns. I installed a new JVC head unit and it worked...for about five minutes. I shut the car off, and pushed the unit back into the dash to secure it. Then, I started up the car and the head unit wont turn on. At first I though I had blown a fuse...I checked every fuse I know of in the car and nothing is blown (I checked the fuse box above the leg area on the driver's side and the box under the hood...are there fuses anywhere else in the car?) If this isn't a fuse, what is it. It's not the head unit itself, because the original one that came with the navigator wont even turn on. I'm lost. Any help is greatly appreciated.
Posted By: bberman1
Date Posted: April 22, 2002 at 10:05 PM
Have you checked your owner’s manual? It will tell you where all your fuses are and which ones do what. Disconnect everything except for your power and see if it turns on. If it dose than one of your other wires is shorting it out. I would also get a voltage tester and start testing to see where you lose power. Also run a continuity check to see if you have a good ground.
Posted By: bberman1
Date Posted: April 22, 2002 at 10:07 PM
Do you have a factory amp? if so you could have a problem their
Posted By: pat28ca
Date Posted: April 23, 2002 at 12:36 AM
sometimes the car's computer sends a signal to the original head unit and the head unit will send a signal back to the car's comp. if you blew the curcuits on that then your sol , you'll probably need a new comp.  check to see if any other functions don't work. like a light somewhere or defog or something small like that. chances are that your gonna find something else not working. but definetly check to see if your wires have power( use a dmm or a test light)and make sure that you have proper ground and power(12 constant and 12 switched). good luck
Posted By: Velocity Motors
Date Posted: April 23, 2002 at 12:41 AM
Have you taken out the JVC and rechecked your wiring ? Sometimes when the wires get pushed back into the deck they get pinched and pull out from the harness. Check to see if all your connections are secured and get back to us on it.
