How to install cab lights (on top of roof)
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4170
Printed Date: May 04, 2026 at 10:13 PM
Topic: How to install cab lights (on top of roof)
Posted By: Eliseo
Subject: How to install cab lights (on top of roof)
Date Posted: October 03, 2002 at 10:51 PM
I would like to know if anybody knows or has ever installed the amber lights that go on top of the cabs of pick-up trucks ( like the semi trucks have ).  What is the best way to keep them from leaking? And how do they get hooked up? If somebody could help I would really apprieciacte it.
Thanks,
Late, E. Mendez
Posted By: Velocity Motors
Date Posted: October 04, 2002 at 5:24 PM
You have to take the roof liner off and drill in small holes where you want the lights to go. Then run the wires from the roof to the dash area where your parking light wire is and you've got working lights.
Posted By: SOUND PRESSURE
Date Posted: October 05, 2002 at 12:08 AM
Remember to seal the holes very good or else you will have a "car pool" that was a corny joke!
Sound Pressure
Date Posted: October 05, 2002 at 8:40 AM
Use a clear silicone based sealant for this that you can get at any hardware store.
Posted By: Eliseo
Date Posted: October 06, 2002 at 11:50 PM
    Thanks for the advise guys You don't know how much I appreciate it. I have just a couple more questions.
     Does the silicone go on the inside or outside or both.  Also can you please advise me if the 5 lights positive wire all go hooked up to the trucks parking lights, or can I just run one wire and hook the lights up to it. ( Do I need to put a fuse to these lights ). Do I also have to run a separate ground wire or can I ground them on the roof with the screw that bolts the lights down.  Sorry for all the questions I'm trying to do this on my own so I'm trying to cover all the bases before I get started.
Late, E. Mendez
Date Posted: October 07, 2002 at 12:04 AM
I would put silcone where the hole is, make a round circle with the silicone and once you place the light over it, it will flatten under the rest of the light.
If these lights are intended for use when you have your parking lights on then yes, to the parking lights you can connect them. You can run two wires and then hook your lights in parallel to your parking lights grounding them well to chasis. It's always best and safe to fuse everything. Although in some cases it is not needed but is better to be safe than sorry.
Sound Pressure
Posted By: Eliseo
Date Posted: October 07, 2002 at 11:18 AM
 So would you say that I should or shouldn't fuse it at the light switch? If so what size fuse should I use.
Late, E. Mendez
