My Updated System
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=443
Printed Date: April 02, 2026 at 11:41 AM
Topic: My Updated System
Posted By: Am pM HooDluM
Subject: My Updated System
Date Posted: April 24, 2002 at 7:40 PM
1997 Ford Ranger ExCab 4x4
Kenwood CD Deck DHD EQ with Sub Output
Front - Cerwin Vega HED 5 1/2 Component Rear - Cerwin Vega HED 3way 6x8 AMP - Power Acoustik 2channel *bridged each channel*
Rockford Fosgate 800a2 2 - Audiobahn Alum12x *running 3ohms each* American Accessories 1 Farad Cap ----------------------------------------- These Alum12x are pounding at like 300-400rms
Please tell me wha u think of this
ThE HooDluM
Posted By: NyxBass
Date Posted: April 25, 2002 at 4:59 PM
Sounds good to me. What is powering the rear speakers though? Deck power? You might have a few balancing issues with that...just somehting to be aware of. A four channel amp would let you run all four speakers at the same (or near same) level. and when you say "*bridged each channel*", do you mean bridged into one channel? Bridging, in essence, means using two channels to power one speakers (or set of speakers), effectively combining the output power. If you bridge the power acoustik, you'll have 1 channel...to power what?
------------- /NyxBass
Date Posted: April 25, 2002 at 11:16 PM
when i mean bridged is that i got the front 2 speakers on one channel and the rear 2 speakers on the second channel....the speakers are 4ohms....so bridging 2 speakers on one channel drops to 2ohms....so i got 2 channels running at 2ohms....my only problem with the kenwood deck is that my cd skips everyonce while when i have it turned up.....but it pounds like a motha...eheh
Posted By: NyxBass
Date Posted: April 26, 2002 at 12:40 PM
Ahhh..I see what you mean. In that case, it would be running the amp at 2 ohms, not "bridging." I think you've been misled to the meaning of bridged. Bridged is combining two (or more) channles into one, while you are talking about runnning more speakers in parallel to drop the load on the amp channel. It should work fine, but realise you won't get stereo...not a big deal if you're not into SQ and want the SPL. Mono is the way to go for that.
